I'm trying to build a preamp to connect a (balanced) microphone to an unbalanced amplifier, or to the microphone input of my smartphone.
This is the schematic:
A first LM741 is used to split the voltage from the battery to create a ground reference. Then I use one of the op-amps in a NE5532 as a differential amplifier, to 'convert' the balanced input to an unbalanced signal. The output of this op-amp goes to a passive low-cut filter, and to the input of a second LM741, that drives an analog VU meter (just as a non-inverting amplifier). Since the input impedance of the main amplifier would change the low-cut frequency, I used the second op-amp in the 5532 as an output buffer.
Some of the component values:
R2 = R3 = 33kΩ
C7: 47nF
R9: 6.8kΩ
R10: 50kΩ (sets the low-cut frequency)
R11: 1MΩ
C8: 4.7µF
I have two questions about this design:
1. Why R11? If I disable the low-cut filter (using S2), the output is very weak and distorted. By adding a 1MΩ resistor between the input of the op-amp and the ground, this problem is solved. But what is the explanation?
2. When I connect the output to the input of my smartphone, everything works fine, but when I connect the output directly to the line input of an amplifier or an analog mixer, the VU meter stops working. By adding a resistor (1.5kΩ) either in series with the output (between C8 and J3) or in parallel (between J3 and ground) this problem is solved. But this doesn't seem like an elegant solution, and I do not have a clue why this happens.
Could anyone explain this (seemingly) strange behaviour?
Of course, any other remarks on the design are welcome as well.
Thanks in advance !
Pieter
R2 = R3 = 33kΩ
C7: 47nF
R9: 6.8kΩ
R11: 1MΩ
C8: 4.7µF
Thanks in advance !
Pieter
