Hey Guys. I have a question about connectors and op-amps. Are there connectors that are made to allow for a solder-free connection between a 1mm op-amp pin and a 12 gauge wire? Trying to solder 12 gauge wire onto these tiny pins is a real challenge, especially when attempting to trouble shoot. The op-amp I am using is an OPA549t. I can't use a breadboard because the amplifier circuit will be set up such that the op-amp outputs 8A of current. I really pray there is some sort of quick-disconnect/connector out there designed for this specific purpose (something like this, but made for an op-amp, would be ideal: http://www.grainger.com/Grainger/3M-Female-Disconnect-4X315?Pid=search). Can someone give me an idea where I can find this sort of item for my op-amp pins? I really hope it exists...
