Op-Amp output calculation
Discussion in 'Homework Help' started by StuckStudent123, Sep 23, 2016.
  1. StuckStudent123
    Sep 23, 2016
    10
    Is anyone able to help me with this op amp calculation?
    It's the 1k resistor that's confusing me a bit. If it wasn't there I'd imagine it would just be a simple differential amplifier (but I might be wrong there too:D).
    Rx=2k, V1=3v, V2=9v and the question asks for V0.
  2. AlbertHall
    Jun 4, 2014
    2,270
    448
    I can't open the picture.
  3. StuckStudent123
    Sep 23, 2016
    10
  4. AlbertHall
    Jun 4, 2014
    2,270
    448
    That one requires me to log in.
  5. StuckStudent123
    Sep 23, 2016
    10
    Third time lucky!
  6. AlbertHall
    Jun 4, 2014
    2,270
    448
    OK!
    What is the voltage at the inverting input? Hint: No calculation required.
    Given that, you know the currents in Rx and the 1k resistors and therefore the current in the 2k resistor. Now you can calculate Vo.
    StuckStudent123 likes this.
  7. StuckStudent123
    Sep 23, 2016
    10
    So do you not have to do anything with V1, the non-inverting?
  8. AlbertHall
    Jun 4, 2014
    2,270
    448
    You most certainly do!
    The output voltage is the difference between the input voltages multiplied by the gain of the amplifier. If we are taking the gain of the amp as infinite, what does this tell you about the voltage difference between the inputs?
  9. StuckStudent123
    Sep 23, 2016
    10
    That it's almost 0?
  10. AlbertHall
    Jun 4, 2014
    2,270
    448
    Yep, and you know the voltage at the non-inverting input so...
  11. StuckStudent123
    Sep 23, 2016
    10
    They're the same?
  12. AlbertHall
    Jun 4, 2014
    2,270
    448
    Yep.
    Now you know the voltage at the non-inverting input, you can calculate the current through Rx and R1
    And what is the current into the non-inverting input of the amp?
    And therefore what is the current in R2?
  13. #12
    Nov 30, 2010
    16,703
    7,341
    Any op-amp running properly in a closed loop gain scenario will null its inputs.
  14. AlbertHall
    Jun 4, 2014
    2,270
    448
    Important result to remember.
    #12 likes this.
