OP AMP Lockup
Discussion in 'General Electronics Chat' started by jaclement, Jul 11, 2011.
  1. jaclement
    Thread Starter Active Member
    Apr 15, 2009
    34
    I have read somewhere that NE 5532 or AD712 op amps will lock up if the negative power supply voltage does not come up before the positive. I may have this backwards. I have a circuit that will lock up the first time power is applied, but if the circuit is cycled off and then back on rapidly, it works fine. I built this audio amp 15 years ago and can't remember where I saw this.
  2. ErnieM
    Apr 24, 2011
    7,440
    1,627
    15 years ago that may have been true as the isolation structures inside the chip got forward biased if the power came up wrong. I looked over the data sheets of those devices and saw no warnings about such, so I would imagine the manufacturers upgraded their processes.
    Your "fix" may be as simple as to buy a new op amp and replace.
