Hi all,
I have an opamp LM741 which require a Vcc and Vss to operate. I plan to give it +15V Vcc and -15V Vss. The problem is when i only connect +15V to the Vcc pin (pin7) on the opamp, the Vss pin (pin4) shows +13V plus plus when i measure it with voltmeter. I wonder why this happen? Is this normal? The Vss pin should shows 0V because i not yet connect a -15V to pin4,right?
