Op amp integrator
Discussion in 'General Electronics Chat' started by Gibson486, Dec 19, 2013.
  1. Gibson486
    Jul 20, 2012
    199
    12
    I was looking at op amp integrators....
    I found this site...
    http://www.docircuits.com/learn/tag/sine-wave/
    I am kind of confused as to what R4 and R7 does in the circuit. Is it just there to make sure it is no referenced at zero (it shifts it up to a non zero center value on the scope)?
  2. GopherT
    Nov 23, 2012
    6,301
    4,020
    They should be equal to the parallel resistance of the two resistors connecting to the inverting input to balance the offset. They are not really needed for high input impedence op amps. A wire from non-inverting input to ground is all that is needed.
