op-amp integrator with reset
Discussion in 'Homework Help' started by ivkil, May 24, 2013.
  1. ivkil
    Nov 23, 2012
    Hello! I'm new in electronics. I have a sine wave on the input and my task is to obtain the triangle wave with spikes on the output (see pic.)[​IMG]
    I try to solve this problem. Firstly, I obtain a square wave with the help of op-amp, then integrate it with the help of op-amp integrator with reset on FET. But switch does not work. I have triangle wave on the output (without exponential function).
    This is scheme. Maybe there is some mistakes (I rewrite it from the book).
    Thanks. Please help!
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    I included (among other components) R3 & R5 to obtain the desired output.
    Some other mods were required to obtain the correct waveform phase relationships.
    The solution isn't ideal but it's a start.
    ivkil likes this.
  3. t_n_k
    Mar 6, 2009
    5,448
    783
    FYI - The waveforms for input & output are as attached.
    ivkil likes this.
  4. ivkil
    Nov 23, 2012
    Thank you. Can you give me your circuit parameters? (maybe attach your program simulation file)
