Thank you, Carl.Hysteresis in this case means the output for an input going in one direction is different from the output for the same input going back in the opposite direction.
Look at those definitions again. One of them even specifically states that hysteresis means that the present state is a function of the history and whenever you talk about an effect lagging behind the cause, that means that, somehow, the 'cause' is being remembered.But no definition of 'hysteresis' suggested anything close to "memory", or does it?
by Aaron Carman
by Jake Hertz
by Duane Benson
