Hi Good Day,
I was wondering what are these parameters (-Input and +Input Resistance per the data sheet) and how will I be able to test it? Is this the resistance on the inverting and non-inverting input of an op amp or is this the resistance on the ±15V supply voltage of the op amp? Thank you!
http://www.analog.com/static/imported-files/data_sheets/AD844.pdf
