Op amp homework problem
Discussion in 'Homework Help' started by KuroRyu, Oct 10, 2007.
  1. KuroRyu
    Oct 10, 2007
    Hey, I'm kinda stuck on a rather trivial problem and I need some help. My main problem is whether this would qualify as a "difference amplifier"? Because if it does then I think (correct me if Im wrong) the answer would be obtained by the use of superposition.
    The problem is:
    thanks in advance!
  2. KuroRyu
    Oct 10, 2007
    I see that I made a mistake with the input voltage (the left side) which ofc. should say V(index)i not and Vo.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Yes, the circuit is a difference amp.
  4. Distort10n
    Dec 25, 2006
    429
    It is a difference amplifier, and superposition is the easiest way to solve the problem.
  5. KuroRyu
    Oct 10, 2007
    great! thank you.
