op amp help with vout
Discussion in 'Homework Help' started by kirillavitch, Oct 5, 2011.
  1. kirillavitch
    Oct 5, 2011
    I am totally lost about this problem. The circuit layout is the same as the pic just that the3uA is replaced with 27uA and I need to calculate Vout ..
  2. kirillavitch
    Oct 5, 2011
    The top most resistor is 33 kΩ
  3. Georacer
    Nov 25, 2009
    5,151
    1,266
    Are you familiar with the superposition theorem? It reduces the analysis to three simple OpAmps circuits.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    There are a couple of initial assumptions you might also need to make.
    If the op-amp is considered to be ideal. Then ....
    1. The input currents to the op-amp input terminals are zero.
    2. The amplifier output resistance is zero.
    These points will then assist with the analysis.
