Op-amp freq. response
Discussion in 'Homework Help' started by Musab, Nov 29, 2010.
  1. Musab
    Sep 20, 2008
    25
    Is the frequency response analysis of the op-amp valid if it is saturated ?
    I have applied an input signal with fixed amplitude, and i varied the frequency and recorded the gain at each frequency. Then I realised that the input causes the amplifier to saturate, so I want to know if the cut-off frequency and the roll-off will change if the amplifier is not saturated.
    Thanks,
  2. mik3
    Feb 4, 2008
    4,846
    63
    The amplifier has not to be saturated in order to determine its cut-off frequency correctly.
    Musab likes this.
