Op amp for power supply question
Papabravo
Joined Feb 24, 2006
21,225
That and there is a huge difference between a power opamp and an audio amp. Why do you think an LM386 is an appropriate substitute?
KLillie
Joined May 31, 2014
137
Papa, I guessed it it probably wasn't. I hoping someone would say it would work OK. Or that someone more learned than I would explain why it is not an appropriate substitute. RJohnson just sunk my battleship. I am still interested in knowing where to look in a datasheet to find whether an op amp is stable at unity gain.
RJohnson
Joined May 29, 2011
21
Sorry about that. Often times the data sheet will say "Unity gain stable". I also think single supply are if not said otherwise but I'm not sure about this.
