Op Amp enable/disable
Discussion in 'General Electronics Chat' started by Cuetek, Feb 4, 2011.
  1. Cuetek
    Jul 31, 2010
    [​IMG]Hey Guys (and Grrlz),
    I need to turn one of these two op amps on and off as simply as possible with a digital signal (VCCDIG-0V). Maybe a high side FET or something? Anybody got any good ideas?
    [​IMG](see response below for schematic)
    Thanks, -Mikey
  2. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    Do you have a schematic?
    You can upload it here on the forum:
    Bertus
  3. Cuetek
    Jul 31, 2010
    Here it is (I hope).
  4. bertus
    Administrator
    Apr 5, 2008
    15,803
    2,388
    What is the purpose of switching the opamp on and off?
    You could change the gain setting with an analog switch (like a 4066 or DG502) if you want too.
    Bertus
  5. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Can you use an analog switch to disconnect the output of one amplifier from the rest of the circuit?
  6. Cuetek
    Jul 31, 2010
    Analog switch to change the gain would be spot on. I'll go check it out. Thanks
