Op amp: Differential config.
Discussion in 'Homework Help' started by Steve1992, Mar 26, 2010.
  1. Steve1992
    Thread Starter Senior Member
    Apr 7, 2006
    100
    I came out with this solution for Vo:
    (V1 - V2) x (Rf/Ri +1).
    But its hit or miss when I change the values in a simulator.
    How would solve it?
  2. Jony130
    Feb 17, 2009
    3,995
    1,117
  3. The Electrician
    Oct 9, 2007
    2,301
    339
    Just guessing, I would think something like this would be correct:
    Vo = V1(Rf/Ri + 1) - V2(Rf/Ri)
    But then you still have the problem of determining V1 and V2 (V1 being the + input of the opamp).
    You have two things labeled V1 on your schematic; bad practice.
