OP-AMP design
Discussion in 'Homework Help' started by ironmike828, Sep 2, 2010.
  1. ironmike828
    Jan 29, 2010
    13
    I have a question regarding a circuit that would take the average of 4 inputs and have an output as the average of the 4 inputs using an Op-Amp.
    First the equation would be Vo = (V1+V2+v3+v4)/4, so assuming all positive inputs you rewrite that as Vo = (1/4)V1...(1/4)V4.
    I figured you set the feedback resistor to 40k, then the input resistors would be 160k in series with the input voltage source. The input voltages would be tied to the positive terminal of the opamp and the negative side would be grounded.
    Obviously something is wrong, can I get some direction on where to go from here?
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
  3. ironmike828
    Jan 29, 2010
    13
    wow that never occured to me, i def over thought that problem. Thanks a lot!
