[Op-Amp] current for max. output swing
Discussion in 'Homework Help' started by krlngc, Nov 8, 2015.
  1. krlngc
    Dec 9, 2013
    11
    Hi all,
    For the op-amp circuit in attachment i'm asked to find the I_3 current that renders the output swing maximum and the R_E that allows input swing between -1V +1V. The circuit parameters are given as;
    V_CC=5V
    V_EE=-5V
    I_1 =  50uA
    I_2 = 500uA
    R_L = 1K
    I think thatI_3 sets the bias point for Q7 and determines the transconductance. In small signal case, the positive half-wave of the input will cause the i_c to flow over R_L and the negative half-wave will result in a negative current over R_L in order to complete I_3. However I can't go any further. How can I make any comment about the max output swing? What should be my approach on this question?
    Thank you for your help.
  2. Jony130
    Feb 17, 2009
    3,990
    1,115
    What about the situation when Q7 is in cut-off?
  3. krlngc
    Dec 9, 2013
    11
    I can't really tell what drives Q7 to cut-off. A significant rise in V_E can reverse-bias the BE junction maybe ? Is this my upper limit?
  4. Jony130
    Feb 17, 2009
    3,990
    1,115
    Q6 can cut-off Q7 transistor. And when Q7 is in cut-off, you will get maximum negative voltage swing.
    But on the other hand when Q6 is cut-off you will get the maximum positive voltage swing.
  5. krlngc
    Dec 9, 2013
    11
    I see now. But how can Q6 cut-off Q7 ? By stealing all the current that I2 provides?
    Thank you.
  6. Jony130
    Feb 17, 2009
    3,990
    1,115
    Do you see any other way??
