I want to make a circuit using the following components:
I need help with the Comparator, i.e. how should I connect to make it behave the way I intend?
Here's a picture of the TL064 op amp, where you can see the connections:
Which connections should I connect into the circut?
Also attached: Data sheet for TL064: http://www.edaboard.com/attachments/98727d1384799087-nrtl061-tl064_e.pdf
Help is appreciated
I want to build the circuit so that heating up the NTC-Thermistor with two fingers (which make it go to about 7.14 kΩ) will activate the TL064 op amp and make it switch and make the light of a LED start to shine.* 9 V battery
* TL064 op amp (as a Comparator)
* NTC-Thermistor 10 kΩ
* LED, forward biased at 2.7 V
* Resistors (I have lots so can pretty much use anyone)
Help is appreciated
