Op Amp Circuit
Discussion in 'General Electronics Chat' started by lyndia, Jul 31, 2009.
  1. lyndia
    Jul 31, 2009
    http://rapidshare.com/files/262188689/opamp.JPG.html
    This is an op amp circuit from the datasheet of OPA567 (top of page 19 of the datasheet). I was wondering if it is possible to modify this circuit such that it uses positive supply instead of negative, and sources current instead of sinking it.
    Thanks.
  2. bertus
    Administrator
    Apr 5, 2008
    15,806
    2,389
    You can post the circuit directly here.
    A sharing site is not so well done over here.
    A lot of people do not trust files from there.
    You can attach a file with the "manage attachments" a litthe bit down the page.
    Greetings,
    Bertus
  3. lyndia
    Jul 31, 2009
    Thanks I didn't see that.
    It's posted now.
  4. KL7AJ
    Nov 4, 2008
    2,047
    295
    Absolutely. In fact the 567 is designed primarily to work with a single positive supply. Like just about any op amp the choice of ground reference is pretty arbitrary. Just be sure to modify ALL your ground points to reflect this!
    eric
  5. lyndia
    Jul 31, 2009
    Thanks.
    Apart from changing positive supply to using +5V and negative supply to using ground, is there any other modification which I should make for the circuit to work as a current source?
    Sorry but I'm fairly new to doing circuits.
