For the circuit below, determine VOUT where R1=R2= 10 KΩ, R3 =100 KΩ, R4= 30 KΩ,
R5=40 KΩ, R6=30 KΩ, VS1=VS2= 2 volts.
I understand that but the only thing I was able to come up is that R3 and R4 have 0 current going through. From there I am stuck.The rules for Homework Help are we don't do your work for you. Show us your work and we can guide you from there.
The question is to find the voltage of the output. I am not expecting you to solve the question I just need some guidance as to where to go about solving the problem.So, again, what is your question? Are you expecting someone to just work your homework for you? If not, what ARE you expecting? Your thread title says you have an op-amp circuit question, but you have yet to ask any question at all.
What are the consequences of having no current in R3 and R4? Are there any nodes for which you CAN determine the voltage for? What nodes will end up having the same voltages as a consequence of the op-amp operating in its active regime?
