Op amp circuit identification
Discussion in 'Homework Help' started by notoriusjt2, Dec 14, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    I am thinking that circuit #1 is a low-pass filter because of the cap and resistor in series on the feedback leg
    #2 I am thinking that is a high-pass filter
    I am thinking this one is also a low-pass filter based on this article
  2. t_n_k
    Mar 6, 2009
    5,448
    783
    Looks like a Wien Bridge Oscillator.
  3. thatoneguy
    Feb 19, 2009
    6,357
    718
    Since both inputs are tied to ground, and there are two capacitors in the positive feedback path for phase shift, I would guess the top circuit to be an oscillator.
  4. notoriusjt2
    Feb 4, 2010
    209
    is this one (#2)
    a bandpass filter because it has both a low pass and a high pass filter within it?
  5. thatoneguy
    Feb 19, 2009
    6,357
    718
    LM102 Datasheet, Page 5 shows examples of high pass and low pass filters.
    You might recognize a circuit on that page as well. :D
  6. notoriusjt2
    Feb 4, 2010
    209
    haha one of those looks awfully familiar
    so circuit #2 has both a high-pass and a low-pass filter in it
    which makes it a band-pass filter right?
  7. Wendy
    Mar 24, 2008
    20,772
    2,540
  8. notoriusjt2
    Feb 4, 2010
    209
    the second one is neither a band-pass filter or a high-pass filter.
    I have failed at op-amp circuit identification. LOL
  9. Jony130
    Feb 17, 2009
    3,993
    1,116
    The second diagram show AC-coupling audio-band non-inverting amplifier.
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    Presumably you refer to that somewhat blurry colored figure?
    I would have thought 'effectively' a high pass filter.
    There are two poles at ω=1 rad/sec and ω=10 rad/sec. There are two zeros at ω= 0 rad/sec (i.e. DC) and ω=0.1 rad/sec.
    So DC gain is zero. Gain rises from 0 to 0.1 rad/sec at 20dB per decade. From 0.1 rad/sec to 1 rad/sec the gain rises at 40dB per decade. From 1 rad/sec to 10 rad/sec the gain rises at 20 dB per decade and from 10 rad/sec the gain begins to level out to a final high pass value of 20dB.
    What is the correct answer according to your teacher?
  11. notoriusjt2
    Feb 4, 2010
    209
    Prof says that it is an AC noninverting op amp
  12. t_n_k
    Mar 6, 2009
    5,448
    783
    As Jony130 correctly indicated.
    Interestingly, if one were presented only with the Bode plot (magnitude / phase frequency response) rather than the circuit diagram itself, then it would be equally valid to state the response as being consistent with that of an active high-pass filter.
  13. thatoneguy
    Feb 19, 2009
    6,357
    718
    I agree.
    Should have gotten partial credit.
    notoriusjt2: Sorry Jony130 didn't reply in time. :D
