Op-Amp Circuit Analysis
Discussion in 'Homework Help' started by ginebra, Jan 20, 2012.
  1. ginebra
    Mar 9, 2011
    5
    Hi I'm stumped with my homework and I would like to ask some help to guide me in answering. I have answered the first part and would like to confirm if my analysis is correct.
    For both problems, ideal op-amps are used.
    For circuit A, my answers are Vout = 9V, V1 = 3V, I1 = I2 = 3 mA and I3 =0.
    For circuit B, I am unsure of my answers since I do not know if Vx = 9 V or Vx = 0.7 + Ie(2K + 1K). In addition to the unknowns, I also have to solve for the power dissipated by the transistor.
    I hope that someone can help me see the light. :D Thanks in advance.
  2. Jony130
    Feb 17, 2009
    3,993
    1,116
    For circuit A the voltage gain is equal to 1 + 2k/1K = 1+2 = 3V/V
    So Vout = 3V * 3 = 9V
    If we assume ideal op-amps are used then
    V1 = 3V and I1 = 3V/1K = 3mA
    And Vx voltage is equal to Vx = ( Vin * (1+ 2K/1K) + Vbe) ≈ 9.7V
    And the power dissipated by the transistor is equal to
    Ptot = Vce * Ic = ??
  3. ginebra
    Mar 9, 2011
    5
    Thanks. It's nice to see I got the correct answers for circuit A.
    However, In circuit B, isn't the KVL equation Vx = ( Vin * (1+ 2K/1K) + Vbe) ≈ 9.7V lacking? I mean shouldn't the 2k and 1k resistors be taken to consideration. Can I assume that Ie = Ic = I1 = 3mA so that I can formulate KVL equations for Vx and Vout?
  4. Jony130
    Feb 17, 2009
    3,993
    1,116
    This equation is not KVL
    Vin = V1 = 3V so
    I1 = 3V/1K = 3mA the voltage across 2K resistor will be equal to
    VR2 = 3mA * 2K = 6V
    and from KVL we have
    Vx = V1 + VR2 + Vbe
    Yes you need to assume that I1 = Ie = Ic because we don't know the BETA of a BJT. But in this problem there is a catch. Do you know where ?
    screen1988 likes this.
  5. ginebra
    Mar 9, 2011
    5
    You're right. However I forgot to note that beta is infinite for the transistor. Does that invalidate our assumption that I1 = Ie = Ic?
    Wow there's a catch. Damn. I don't really see one unless we are talking about the transistor being saturated since Vx being much greater than 0.7V. I would greatly appreciate it if you could point it out sir. Please.
  6. t_n_k
    Mar 6, 2009
    5,448
    783
    If the current were 3mA in the 3k, transistor, 2k and 1k what would the voltage drop Vce be, given the supply is 15V???
  7. ginebra
    Mar 9, 2011
    5
    Yeah it's a problem since Vce would be equal to -3V. Maybe there is a typo error in the given.
  8. Ron H
    Apr 14, 2005
    7,050
    657
    I think the catch is that the transistor is saturated. You can still solve for all voltages and currents if you know what Vce(sat) is, or if you assume that it's zero.
  9. hgmjr
    Jan 28, 2005
    9,030
    214
    I agree with RonH's assessment. The transistor is in saturation with the given parameters.
    hgmjr
  10. t_n_k
    Mar 6, 2009
    5,448
    783
    I would also think the op-amp itself is saturated since V1 can't be adjusted to match the 3V input.
  11. Ron H
    Apr 14, 2005
    7,050
    657
    The saturated transistor does not preclude the op amp from forcing V1 to 3V. The emitter will be at 9V, the collector at (9V+Vce(sat)), and the base at 9.7V. The op amp has to contribute 1mA to the feedback resistor, through the forward-biased base-collector junction.
    t_n_k likes this.
  12. ginebra
    Mar 9, 2011
    5
    Thanks for all the help. I understand now.
