Op Amp Circuiit Questions
Discussion in 'Homework Help' started by MoonLight94, Oct 30, 2015.
  1. MoonLight94
    Oct 30, 2015
    Hello there I have a problem with this questions I hope if u can help me with them :)
    My problem is how to get Vo in these questions ..
    first one because of the non inverting feed back
    and the second one is because of the Complexity of the circuit ..
    and the in advance
      File size:
      37.6 KB
      11
      File size:
      17.5 KB
      12
  2. dl324
    Distinguished Member
    Mar 30, 2015
    3,377
    651
    Are these homework questions?
  3. WBahn
    Mar 31, 2012
    18,087
    4,917
    MOD NOTE: Moved to Homework Help (because it looks like homework).
    If this is homework, you need to show your best attempt to solve the problem. We can then look at your attempt and identify what you are doing right and what you are doing wrong and help get you on the right path.
  4. MoonLight94
    Oct 30, 2015
    great I'll Do my best, but i really don't know from where to start with the non inverting feedback
  5. WBahn
    Mar 31, 2012
    18,087
    4,917
    Remember that what you are looking for is an output voltage that is stable for the given input (since this isn't an oscillator, hopefully). Also keep in mind that the output voltage is limited to being between the power supply voltages.
    MoonLight94 likes this.
  6. RBR1317
    Nov 13, 2010
    265
    54
    Analysis of an op-amp circuit wired for negative feedback always starts with the realization that the voltage difference between the op-amp inputs is just a few micro-volts. For an ideal op-amp with infinite gain, the voltage difference is 1/∞ or zero.
