Op-amp Characteristics Help
Discussion in 'General Electronics Chat' started by electron_prince, Sep 22, 2012.
  1. electron_prince
    Sep 19, 2012
    93
    Does it mean that in ideal op-amp there is no output when differential voltage between terminals is zero. And in practical op-amp there is no output when the differential voltage is equal to the Input Offset Voltage?
    under what conditions are the current in the terminals measured?
    Doesn't the mismatching between terminals give different results at inverting and noninverting terminal?
    In the multimeter we have two leads (red and black). If I connect the red lead with one terminal of the op-amp, where do i connect the black lead?
  2. bertus
    Administrator
    Apr 5, 2008
    15,801
    2,387
