op amp buffer
Discussion in 'The Projects Forum' started by Ilovecircuits, Oct 15, 2009.
  1. Ilovecircuits
    Oct 15, 2009
    5
    I've built a oscillator, using a 4Mhz, crystal. I want to amplify the 4 Mhz sine wave coming out of the crystal. I used a op amp buffer. Connecting the inverting input to the ouput, and the non-inverting input, to the output of my oscillator. To no avail will it amplify the signal, the output of the buffer looks nothing like my signal. Any suggestions for amplification of such a signal, and yes I'm using a high speed op amp.
  2. StayatHomeElectronics
    Sep 25, 2008
    864
    40
    Can you post a schematic of what you are trying to do, including part numbers for major components?
  3. hgmjr
    Jan 28, 2005
    9,030
    214
    It does sound like your opamp is unable to respond to the 4MHz signal. Not surprising really. Commonly available opamps are not typically capable of handling frequencies in the 4 MHz range.
    hgmjr
  4. ELECTRONERD
    May 26, 2009
    1,146
    16
    Buffers are more for impedance matching, and so I doubt they would amplify your signal much. Is impedance a primary issue in your project? Otherwise, you might consider using a different format design.
  5. Ilovecircuits
    Oct 15, 2009
    5
    I just want to amplify the signal of the oscillator. I've attached the schematics of what I'm using. If I don't use an omp -amp since ELECTRONERD said a different design might be better ideas?
    But how come my op amp doesn't have the same signal output, is the signal generated from the crystal too weak?
    The top circuit is my oscillator
    The middle circuit is the voltage follower.
    The bottom circuit is the voltage regulator coming into the oscillator +12V
    I'm using a 2N222A npn transistor. The voltage regulator uses the LM317 chip. The crystal is just a standard 4 Mhz crystal
  6. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    What is the op amp? It is arranged as a follower, so even if it can run at 4 MHz, it will not amplify the signal.
  7. Audioguru
    Dec 20, 2007
    9,411
    896
    The opamp is not powered.
    It is not DC biased properly.
    Since it is a follower with no voltage gain then its output will be exactly the same as its input if it is powered and biased properly.
  8. Ilovecircuits
    Oct 15, 2009
    5
    I guess I didn't make it apparent in my diagram, I am hooking up my op amp to +15 and 15 voltage sources.
    Shouldn't this give me atleast unity gain?
  9. steveb
    Jul 3, 2008
    2,433
    469
    It should, but you still haven't told us the part number on the OPAMP.
    Is it top secret?
  10. blueroomelectronics
    Jul 22, 2007
    1,758
    98
    My guess is a 741
  11. russ_hensel
    Distinguished Member
    Jan 11, 2009
    820
    47
    A video op am should have high frequency response, but normally fairly low input impedance. Can easily turn into ossc. But do some research it may do it.
    Since the transistor works why not add another transistor stage.
  12. Ilovecircuits
    Oct 15, 2009
    5
    I've used the LM318 and MC33074 op amps.
    Do I have to connect pins 1,8 and 5, or can I ignore those on the MC33074.
    I do have two supplies also, for +15, and -15 biasing.
  13. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
  14. Audioguru
    Dec 20, 2007
    9,411
    896
    The datasheet for the MC33074 shows that its output swing at 4MHz ia almost nothing.
    At 4MHz its gain is less than 2.
  15. steveb
    Jul 3, 2008
    2,433
    469
    This is good general advice, but there is still a mystery here. Both opamps should give some response at 4 MHz when used as a unity gain buffer. And the MC33704 should still operate with dual power supplies, even though it is a single supply opamp.
    I think audioguru was on the right track previously. He mentioned the DC biasing. You can't drive the input of the opamp with capacitive coupling. There needs to be a DC path into noniverting terminal on the OPAMP.
  16. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    Agreed about the response - I misread it as 40 MHz. A resistor to ground can give a 0 volt reference on the noninverting pin - the question is still how much gain?
  17. Ilovecircuits
    Oct 15, 2009
    5
    what if I change the npn transistor im using a 2n2222, is that not puting out enough power?
  18. steveb
    Jul 3, 2008
    2,433
    469
    Are you still using capacitive coupling from the output of the oscillator to the input of the opamp. If so, you need to provide a DC path on the input of the opamp noninverting terminal. "beenthere" mentioned using a resistor to ground which should work if the value is large enough to not load down the output of the oscillator.
