op amp buffer Vo not right
Discussion in 'General Electronics Chat' started by Gibson486, Dec 5, 2013.
  1. Gibson486
    Jul 20, 2012
    199
    12
    I have an op amp buffer with an MCP601. The issue I am having is that the output is off by 200mV. The input on the positive side is simply from a divider that downscales the input by 9/10.
  2. crutschow
    Mar 14, 2008
    13,496
    3,373
    Need a circuit diagram.
  3. Gibson486
    Jul 20, 2012
    199
    12
    pic attached
  4. LvW
    Jun 13, 2013
    674
    100
    Are yu sure that the "offset" is not caused by resistor tolerances?
    What means "off"? With respect to which expected voltage?
  5. Gibson486
    Jul 20, 2012
    199
    12
    When I say off, I mean the op amp is getting 4.4V at the input, but the output is 4.2V
  6. shteii01
    Feb 19, 2010
    3,500
    511
    That could be op amp itself. Check the datasheet. See how close you can get to the rail. Your rail is 5 volts, but real physical op amps never reach their rail.
    For example 741 op amp, I think, can only get withing 2 volts of the rail. So if you set a rail at 5 volts, the maximum output will be 3 volts, you will never get any higher. This is for 741.
    What op amp are you using? Put the datasheet up.
  7. Gibson486
    Jul 20, 2012
    199
    12
    It's a rail to rail op amp and even so, the input is 4.2V, so I am far from teh rail anyways....
  8. kubeek
    Sep 20, 2005
    4,689
    806
    The opamp says it is rail to rail, so that should not be the issue. Are you sure you have it wired correctly?
  9. shteii01
    Feb 19, 2010
    3,500
    511
    You don't understand. I am looking at Figure 4-3. it says:
    VOUT must be kept below VDD–1.2V for correct operation.
    Your VDD is 5 volts. The maximum VOUT=5-1.2=3.8 volts, that is max, you actually want to stay slightly below that.
    If you can raise the supply (VDD) to 6 volts, then you will be in range where 4.4 volts works.
  10. shteii01
    Feb 19, 2010
    3,500
    511
    I see 5 volts supply and ground. That is single supply configuration. His rails are 0 and 5 volts.
    What rail to rail you are talking about?
  11. Jony130
    Feb 17, 2009
    3,991
    1,115
    You made a small mistake the MCP601 is rail to rail output not the input one. The Common Mode Input voltage range is equal Vdd - 1.2V = 5V - 1.2 = 3.8V.
    Output voltage can reach Vdd - 20mV because MCP601 is a rail to rail output opamp.
  12. Gibson486
    Jul 20, 2012
    199
    12
    Awww man...that sucks...I could have sworn I used this same design for a 0-5V buffer before without an issue. I could have sworn it worked in the past....know any op amps that can do what I want it to do? Is this common of all opamps that are rail to rail?
  13. kubeek
    Sep 20, 2005
    4,689
    806
    Oops missed that, the output is rail to rail but the inputs are not.
  14. shteii01
    Feb 19, 2010
    3,500
    511
    Well, according to Jonny130 I am making a mistake somewhere.
    So far we know that when you put in 4.4 volts, you get 4.2 volts out.
    Try the formula I listed above. Put in 3 volts, see if you get 3 volts out.
  15. Jony130
    Feb 17, 2009
    3,991
    1,115
    Try using TS912
  16. Jony130
    Feb 17, 2009
    3,991
    1,115
    You simply mixed up Common Mode Input Range with Maximum Output Voltage Swing.
  17. BobTPH
    Jun 5, 2013
    806
    121
    Most of the MCP opamps are rail-to-rail input and output. You just happened to choose one of the few that does not.
    Bob
  18. crutschow
    Mar 14, 2008
    13,496
    3,373
    True. But for a follower connection as this is, the output can go no higher than the input maximum common-mode range.
    As a work-around you could configure the op amp with an inverting gain of say 2, and double the input attenuation. That will allow a full-scale output of 5V with the same overall gain.
  19. shteii01
    Feb 19, 2010
    3,500
    511
    We don't even need to do that. The opamp is rated for 6 volt supply. So power it with 6 volts instead of 5 volts.
