Op Amp Based PID controller
Discussion in 'The Projects Forum' started by Salman Anjum, Oct 24, 2014.
  1. Salman Anjum
    Oct 13, 2014
    14
    Hi All.
    I know many people have already discussed this topic before. I have read all the discussions but yet i m stuck.
    I need to build an op.amp P.I.D controller project. I've goggled it but I found nothing except Water-Level control, Temperature Control, Motor Control etc etc..
    Plss recommend me some good projects for my work... (it must use an op-amp based PID)
    Thanks ...
  2. Johann
    Nov 27, 2006
    190
    30
    Temperature control employing PID is a recommended project.
    tshuck likes this.
  3. MrChips
    Oct 2, 2009
    12,633
    3,453
    Automatic gain control (AGC) for example on a microphone amplifier. You want the audio signal being recorded to have the same audio input level.
    Johann likes this.
  4. Salman Anjum
    Oct 13, 2014
    14
    thanks, I'll read about this. If you find any link, you think may be useful for me pls give it to me over here. thanks pal
  5. Sensacell
    Jun 19, 2012
    1,183
    276
    Inverted pendulum balancing machine is a cool project?
  6. #12
    Nov 30, 2010
    16,685
    7,323
    My experience with live performance tells me otherwise. Please elaborate about this application. It's obvious I need some education here.
  7. MrChips
    Oct 2, 2009
    12,633
    3,453
    It depends on the application.
    If you are trying to record someone dictating into a microphone or delivering a speech or song birds in the outdoors, your objective may be to capture a clear recording.
    For recording a live musical performance you may want to turn off the AGC.
    My SW radio has a switch selectable AGC to compensate for signals that fade in and out.
    #12 likes this.
  8. atferrari
    Jan 6, 2004
    2,663
    784
    Search "Bob Pease" "PID" "op amps". The simplest ever.
    Be patient to understand his drawing.
    While there, learn who he was.
