Op-Amp As Gyrator
Discussion in 'Homework Help' started by extremeads1, Feb 16, 2007.
  1. extremeads1
    Thread Starter Active Member
    Feb 10, 2007
    64
    can anybody explain the working of Gyrator ckt Using Op-Amp741
  2. hgmjr
    Jan 28, 2005
    9,030
    214
  3. extremeads1
    Feb 10, 2007
    64
    i have read that article but i was unable to understand .
  4. hgmjr
    Jan 28, 2005
    9,030
    214
    The basic purpose of the gyrator is to simulate the impedance of a inductor. The reason simulation is desireable is that physical inductors with high values of inductance are both large and expensive. Gyrators provide an electronic circuit alternative to these bulky and expensive components. These gyrators do have limitations but these are easily overlooked in favor the advantages they can offer in certain applications.
    Do you have a particular application in mind or are you simply seeking to broaden your knowledge on the subject?
    hgmjr
  5. extremeads1
    Feb 10, 2007
    64
    Yes You Are Right, Sir, I'm determined to Increase My Knowledge In the ELECTRONICS
  6. Papabravo
    Feb 24, 2006
    10,340
    1,850
