Op-amp application
Dritech
Joined Sep 21, 2011
901
Can someone please explain what is the function of the op-amp circuit in the attached diagram? It is like a non-inverting amplifier but resistor R1 is connected to the input instead of the ground.
#12
Joined Nov 30, 2010
18,224
It looks like a voltage follower to me. The only thing I can come up with besides that is a frequency dependent change due to an RC node at the inverting input, but that doesn't seem like it is predictable enough to use as a design parameter. I wonder if it would suddenly become obvious if this was shown in the context of a larger circuit.
ScottWang
Joined Aug 23, 2012
7,397
Where did you get this circuit?
Any explanation from that source?
I saw and checked much more op amp circuits, but I can't find anyone similar like this.
GopherT
Joined Nov 23, 2012
8,009
It's just a buffer when R1 is large (above 100 ohms). Out perfectly matches input when simulated. R1 and R2 can be anything but no change.
As R1 becomes small (e.g 0.1 ohm) it becomes an attenuator - at R2 = 10k and R1 is 0.1ohms, attenuation is 50%. About 90% when R2 is increased to 100k.
LvW
Joined Jun 13, 2013
1,752
Dritech, it is a rather tricky circuit.
It is a unity gain amplifier with one big advantage if compared with the classical buffer having 100% feedback:
It is a circuit with adjustable feedback - independent on gain (that is always unity).
Thus, you can use uncompensated opamps (normally not unity gain stable).
The factor R1/(R1+R2) - and, thus, the loop gain - can be made as small as necessary to allow stable operation - without influencing the closed-loop gain.
Such a circuit is also used for compensated opamps (unity gain stable) to improve the phase margin (step response with less overshoot).
Explanation for operation:
*The voltage at the non-inv. input always is Vin.
*Therefore, the voltage at the inv. input also is identical to Vin (idealized gain of infinite assumed).
* Thus, no current through R1.
* Therefore, no current through R2.
* Result: Vout=Vin
#12
Joined Nov 30, 2010
18,224
"Very interesting". (Arte Johnson)
All these things I know about op-amps and, even after you show it to me, I am stretching to visualize it. Changing the closed loop gain of an amplifier that doesn't have any gain (in the usual sense). That's brilliant, and you'll never see it in an op-amp tutorial. (I think I read all of them.)
Jony130
Joined Feb 17, 2009
5,487
You never heard about noise gain vs signal gain ?
http://www.analog.com/library/analogdialogue/archives/47-03/raq_91.html
http://www.analog.com/library/analogdialogue/archives/31-2/appleng.html
LvW
Joined Jun 13, 2013
1,752
Another example for an amplfier having a noise gain that is independent on signal gain is an opamp with negative as well as positive feedback (for stability reasons, the negative feedback must dominate, of course). This option also allows decompensated amplifiers to operate for low signal gain valus.
However, one should be aware that the signal bandwidth is determined by the noise gain bandwidth (unity loop gain).
GopherT
Joined Nov 23, 2012
8,009
If I remember correctly, the whole Arte Johnson quote was, "very interesting, but stupid". Maybe that is what #12 was implying?
I have seen better attenuator circuits. I'm still trying to get my head around the rest of the story. The Jury is still out, Arte may be right.
