op-amp and delta resistors
Discussion in 'Homework Help' started by caramel, Feb 9, 2007.
  1. caramel
    Feb 9, 2007
    19
    hello :)
    this problem has been driving me insane! "prob3" refers to the original hw problem, and "sol3" refers to my attempts at simplifying it... i just don't know how to simplify it enough that it's workable.. that Vs in the middle of the resistors is confusing me. i tried converting the delta's to pi's, but i don't really see where that's going either.... help :confused:
    oh, btw, i forgot to erase my pencil markings on the problem.. the nodes labeled "Vs" and "-Vs" and the 0A currents going into the op-amp are all my additions to the initial problem.
    thanks in advance!
  2. Ron H
    Apr 14, 2005
    7,050
    657
    Try redrawing it as below. If you're still stuck, post your attempt at the solution.
  3. caramel
    Feb 9, 2007
    19
    thanks! i haven't really attempted to solve what you posted, but by glancing at it i noticed you introduced a couple more unknown variables. i'll try to work it out tomorrow, i hope i'll be able to figure out a way around those variables. thanks once more :)
    i just glanced at it once again.. can i add the 12ohms and the 6ohms, since the wire in between them carries 0A? in other words, can i treat them as if they are in series, is this a correct first step?
  4. Ron H
    Apr 14, 2005
    7,050
    657
    I didn't really think of them as variables, although I suppose they are. I just labeled the nodes as an aid in solving for the output voltage.
    Keep in mind that Vn=Vp. This is one of the keys, but you hopefully know this if you are studying op amps.
  5. Distort10n
    Dec 25, 2006
    429
    Ahh...the classic bridge.
  6. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings caramel,
    Were you able to get any further down the solution path using the important hint that ronh provided concerning the voltages at the op-amp's positive and negative input terminals?
    hgmjr
  7. caramel
    Feb 9, 2007
    19
    thanks for the input so far.
    yes, i know that Vp=Vn, but now i have 3 unknowns instead of 2. i haven't worked through it, but i will right now and re-post my result.
    i'd also like to learn how the initial circuit was simplified to this one.. and what is "bridge?"
  8. hgmjr
    Jan 28, 2005
    9,030
    214
    Here is an introduction to bridge circuits located on this website in the tutorials.
    hgmjr
  9. caramel
    Feb 9, 2007
    19
    thanks for the link :) i'll check it out asap.
    here's my attempt at solving the circuit.. i got stuck, again! i think i need another another KCL and then solve the system of equations, but i don't see where i can apply KCL. after plugging in 1.5Vp for Vs, i end up with one equation 2 unknowns... so what to do now?
    sorry i had to zip it because the pdf file was too big
    • sol3.zip
      File size:
      186.9 KB
      14
  10. hgmjr
    Jan 28, 2005
    9,030
    214
    Greetings caramel,
    I looked at your most recent solution and the one thing that appears to be hanging you up is your tendency to try to confer the value of 0 volts on the input terminals. This is not a valid assumption for this design.
    The fact is that there is enough information in the problem for you to clearly determine the equation for the voltage at the positive terminal using simple voltage divider analysis.
    The equation for the voltage at the op-amp's positive terminal is a good place to begin to break the problem down into smaller bites.
    Can you take a stab at writing that equation and then post it here?
    hgmjr
  11. caramel
    Feb 9, 2007
    19
    hi :)
    the 0's are currents going into the op-amp, sorry forgot to write in my units. i don't really understand what you're asking for. i think i've labeled all my voltage nodes correctly, right?
  12. hgmjr
    Jan 28, 2005
    9,030
    214
    Sorry, my bad. You did label them as 0A which I now understand was your way of noting to yourself that there was no current flowing into or out of the op-amp terminals.
    What I was referring to was the voltage being supplied to the positive op-amp terminal. You should be able to write the equation for the voltage that appears at the junction of the 6 ohm resistor and the 12 ohm resistor as a function of Vs.
    hgmjr
  13. caramel
    Feb 9, 2007
    19
    you mean to divide the voltage so that the 6ohm gets Vs/3 and the 12ohm gets 2Vs/3 ... i still don't see where that would lead to :confused:
  14. hgmjr
    Jan 28, 2005
    9,030
    214
    What that leads to is a critical piece of the puzzle.
    What you have calculated is the voltage Vp.
    With an expression for Vp all you need to do is write a similar expression for Vn and you will then be able to set them equal to each other and solve for Vo.
    hgmjr
  15. caramel
    Feb 9, 2007
    19
    i'm sorry, i'm still not seeing what you're talking about.. so i found that Vp = 2/3Vs, but i've known that and it didn't help. and the only "similar" expression i can write for Vn would be Vn/3.. how would setting them equal to one another get me Vo? for some reason, i'm not seeing the big picture in this, i don't see where all of this is going at all.
    i tried reading that page you gave me the link to about bridge circuits, and i learned new concepts from it, but nothing that would really help with this.
    i hate being so lost :mad:
  16. hgmjr
    Jan 28, 2005
    9,030
    214
    No problem with being lost. That is part of the learning process.
    Notice that the voltage at the negative input is a function of the 3 ohm resistor from Vs, the 4 ohm resistor from Vo, the 3 ohm resistor to ground, Vs and Vo.
    This is just a two source and three resistor circuit that you have seen before. Sketch the circuit on a piece of paper and then you can use Kirchoff's Voltage Law to derive the voltage at the negative input terminal of the op-amp.
    You can do this.
    hgmjr
  17. caramel
    Feb 9, 2007
    19
    i'm probably completely off, but would Vo=20/27 Volts?
  18. Ron H
    Apr 14, 2005
    7,050
    657
    Caramel, do you understand the concept of "virtual ground"? You must understand this before you can solve this problem. Actually, in this case we don't really have virtual ground, we have Vn=Vp. The concept is the same.
    And you said,
    There is no simplification. The redrawn circuit is identical to the original circuit.
  19. Distort10n
    Dec 25, 2006
    429
    I am probably repeating what others have already said, but what I would do is find the symbolic expression of V+ and then substitute it back into the KCL equation for the V- node. Then I would ultimately solve for Vout/Vin.
    What is your equation that shows Vo = 20/27V ?
    This will be a good circuit to put up on my website!
  20. JoeJester
    Apr 26, 2005
    3,401
    1,218
    knightofsolamnus ... what is your website?
