Op amp analysis transfer function
Discussion in 'Homework Help' started by Jacl, Feb 15, 2013.
  1. Jacl
    Feb 15, 2013
    I need a little help here. This is an ideal op amp. I need to find the transfer function Vi/Vo.
    This is what I have so far (nodal analysis):
    Then I'm not sure about the op amp gain , Vb = A * Vo?
    I get confused when I try to proceed.
  2. The Electrician
    Oct 9, 2007
    2,301
    339
    I think you really want to find the transfer function Vo/Vi, don't you?
    Also, the opamp gain is Vo=Vb*A, not Vb=Vo*A
    The two equations you have appear to be the KCL derived relationships at node a and node b.
    You need another equation.
    A = 1+R4/R3, so Vo=Vb*(1+R4/R3). This will serve as one more equation.
    Now you just eliminate Va and Vb; do you know how to do that?
    Jacl likes this.
  3. Jacl
    Feb 15, 2013
    Yes, I meant Vo/Vi. Thanks for your help! I understand it now.
  4. halfknot
    Apr 21, 2013
    6
    Somewhat related question:
    If I have a a 1st order op-amp low-pass filter circuit that also gives signal inversion: How do I perform an ideal op-amp analysis to give the voltage transfer function of the circuit?
  5. The Electrician
    Oct 9, 2007
    2,301
    339
    Start a new thread, post a schematic, ask your question.
    Show what progress you have already made in solving the problem.
