op amp 741
Discussion in 'Homework Help' started by vustudent, Aug 23, 2010.
  1. vustudent
    Thread Starter Active Member
    Mar 11, 2009
    38
  2. tom66
    May 9, 2009
    2,613
    214
    The resistor is used in some configurations to null the input bias current. The bias current flows through the resistor compensating for the bias current of the inverting input (which is usually equal.)
  3. Audioguru
    Dec 20, 2007
    9,411
    896
    The inverting input has R2 supplying the bias current. The non-inverting input needs to have the same value resistor (R4) supplying the same bias current for its input.
    If you used a Fet-input opamp (like the TL071) then R4 can be a piece of wire.
