I think you nailed what I need. Wiki doesn't explain it simply, so I searched somewhere else and I got this:Maybe you want a
Permanent-split capacitor motor?
Ok, I assume that you mean by 90 phase shift that to provide two forces (from the two windings) that act together as a torque?The two basic cap start types are combined permanent cap start/run where there is only one cap used for both starting and remain in for run.
The second has both a start and a run cap, the start cap is to provide sufficient energy to the start winding for the initial start and switch over to a smaller run cap for continuous run.
The reason for the cap is to provide a 90° phase shift in the start winding WRT the run winding, if no capacitor is used the field oscillates across 180° and results in zero rpm.
For your OP question, the single cap start/run cap that is kept in circuit is connected the same way, in series with the start/run winding.
Max.
Basically, if some kind of phase shift (~90°) is not produced initially in a second winding then the magnetic field oscillates across 180°, so no rotation results.Ok, I assume that you mean by 90 phase shift that to provide two forces (from the two windings) that act together as a torque?
Thanks Man, simple and sweet!Basically, if some kind of phase shift (~90°) is not produced initially in a second winding then the magnetic field oscillates across 180°, so no rotation results.
Motors with failed caps can be given a swift turn and will usually run once spun.
Another method instead of a cap used in small motors such as fans is the shading ring, this is a shorted copper turn, the high current in it produces a phase shift in that part of the stator.
Max.
Thanks Max; max info!Your DWG in post and summary in #14 is correct, the one in #6 incorrect, one too many windings.
With the start and run type both caps are in circuit (in parallel) initially, then the start cap is switched out when up to speed.
Max.
by Duane Benson
by Jerry Twomey
by Don Wilcher
by Aaron Carman
