Only positive differential op amp
Discussion in 'The Projects Forum' started by mcgyvr, Aug 3, 2012.
  1. mcgyvr
    Thread Starter AAC Fanatic!
    Oct 15, 2009
    4,791
    976
    How would I construct a circuit similar to a differential op amp but I ALWAYS want the output to be positive.
    So for example V1=non-inverting pin and V=inverting pin
    When V1 is 1.5V and V2 is 3V I want Vout to be 1.5V
    Then if V1 is 3V and V2 is 1.5V I want Vout to still be 1.5V
  2. t06afre
    May 11, 2009
    5,939
    1,222
    An instrumentation amplifier followed by a Precision Rectifier. Use google for links. But this one is one of the best http://sound.westhost.com/appnotes/an001.htm
    You did not say anything about bandwidth. Most of the Precision Rectifier circuits will work fine up to around 100 KHz at least. Above that it may be harder to find a proper solution
  3. mcgyvr
    Oct 15, 2009
    4,791
    976
    blah..too many parts :(
    maybe I'll just take care of it in software..
  4. t06afre
    May 11, 2009
    5,939
    1,222
    Well have it your way then. Nah just joking. If you can do it software. It will be as good as any solution. More ideal than the analog solution
