online course - (Laplace Transform problem)
Discussion in 'Homework Help' started by notoriusjt2, Mar 2, 2010.
  1. notoriusjt2
    Feb 4, 2010
    209
    I am in an online course and the questions/examples from the book are quite terrible. I have read the entire chapter and this is the first question from my chapter quiz. Could someone please post the basic steps(not the answer) needed to solve this problem as I am honstley clueless. I will then use those steps to try to solve the problem. Thank You
  2. loosewire
    Apr 25, 2008
    1,584
    435
    Look up and study in wikipedia,a lot of information on your
    study.
  3. dachikid
    Member
    Oct 19, 2007
    16
    You might want to start by determining the impedance of the circuit withn the time domain. From there it's just a hop-skip and a jump away to the Laplace transform.
  4. t_n_k
    Mar 6, 2009
    5,448
    783
    While it might be informative there's no need to do that.
    This is the process I would adopt.
    1. Convert all components to the 's' domain.
    An Inductor L becomes Ls
    A Capacitor C becomes 1/(Cs)
    A Resistor R stays as R
    2. Treat the circuit as if it is a series-parallel network and solve it using techniques you have applied to series-parallel resistive networks in the past.
    So then, that part of the circuit comprising the (1/2)F (or 2/s) capacitor in parallel with the 1Ω resistor would become
    (2/s)/(1+2/s) [Remember two resistors in parallel - R1*R2/(R1+R2)]
    To this you would add the (4/3)H or (4s/3) inductor term.
    So that entire branch is equal to [4s/3 + (2/s)/(1+2/s)]. That branch is in parallel with the lone (3/2)F or (2/3s) capacitor.
    It's just more fiddly than manipulating purely resistive terms because the algebra is complicated by the terms in 's' - but it's still just a process of careful algebraic manipulation.
    Have a go at doing the problem - even if you go wrong, someone can then help you.
