One resistor or seven?
Discussion in 'General Electronics Chat' started by BReeves, Nov 26, 2013.
  1. BReeves
    Nov 24, 2012
    412
    64
    Going to have 7 switches supplying 12 volts through a resistor(s) to the LED's in 7 optoisolators feeding a micro. In normal operation only one switch will be closed at any one time but some idiot could/will press two just to see what happens.
    I'm thinking I can get away with just a single current limiting resistor on the supply side instead of using a resistor for each opto. Should someone press more than one switch the code will ignore it.
    Can anyone think of a good reason not to use a single resistor?
  2. Meixner
    Member
    Sep 26, 2011
    116
    21
    I would do it with 1 resistor
  3. John P
    Oct 14, 2008
    1,636
    225
    I suppose you should consider the worst-case condition, where someone presses all the buttons at once. How much current is likely to flow then, and how hot does the resistor get? If you don't mind the invalid input to the processor, that's the only thing I can see to worry about.
  4. Alec_t
    Sep 17, 2013
    5,956
    1,132
    About the same as if only one is pressed.
  5. BReeves
    Nov 24, 2012
    412
    64
    Thanks, confirms what I was thinking. Sometimes I don't trust my own judgment.
    3 of the switches are in a locked cabinet, most anyone could hit at one time is 4. The software will only respond to the first input within a given time.
    Guess I could set the resistor value so if two are hit the LEDs will be too dim to fire the opto. Naw, too many variables to make that practical.
  6. Alec_t
    Sep 17, 2013
    5,956
    1,132
    If more than one switch is pressed the LED with the lowest Vf will hog the current and be brighter than the others.
  7. WBahn
    Mar 31, 2012
    18,079
    4,917
    That's in the long run. Initially, they may share the current much more evenly and then, as thermal runaway builds, one will hog the current from the others.
    Also, no two switches are going to be pressed as exactly the same time, so one opto will be fired before the others. In most cases, the micro will respond to one of the switches (may seem like a random choice to a human that percieves things at human time scales) and ignore the others. If that is acceptable, then you are good to go.
  8. crutschow
    Mar 14, 2008
    13,471
    3,359
    If you have sufficient voltage you could connect all the LEDs in series to avoid any current hogging problem.
  9. wayneh
    Sep 9, 2010
    12,368
    3,224
    One more vote for it being OK, as long as the resistor is sized to not burn up if all switches are thrown at once. Adhering to Murphy's law is not optional.
  10. WBahn
    Mar 31, 2012
    18,079
    4,917
    Wouldn't that defeat the very purpose, which is to have seven switches that are used to select which of the seven optoisolators get activated?
  11. WBahn
    Mar 31, 2012
    18,079
    4,917
    If you size it for one switch, then it is sized for pretty much any number of switches. If you have a hundred LEDs and they are all turned on, then the voltage across the LEDs would only go down by something between 100mV and 200mV. So the voltage across the resistor is going to be basically the same and the total current is going to be basically the same, it is just going to be split among all of the switches that are on.
  12. wayneh
    Sep 9, 2010
    12,368
    3,224
    True enough! Should've thought about that a bit more before posting. This would make a nice exam question.
  13. crutschow
    Mar 14, 2008
    13,471
    3,359
    Yup. I misread the requirements. :p
  14. WBahn
    Mar 31, 2012
    18,079
    4,917
    It would, though it would probably have to be phrased pretty carefully in order to be sure that the person didn't give a valid response that was other than what was intended based on a valid, though possibly incomplete, understanding of the circuit and/or the intent.
  15. WBahn
    Mar 31, 2012
    18,079
    4,917
    We all do it from time to time. As long as we keep each other honest, it all shakes out in the end to a net positive.
  16. BReeves
    Nov 24, 2012
    412
    64
    It's for a photo booth, the buttons allow the guest to select options.
    I wrote both the code on the micro that reads the buttons plus the code running on the computer that does all the hard stuff. Gives me allot of control over what can happen when.
