Hello All,
I hope the answer to this question is as simple as the problem. I have a new 13.8 volt 3 amp power supply I have been using for several weeks now to power a device everyday for about 30 minutes (device is in appropriate range in terms of voltage and amperage). Yesterday, for no apparent reason, I went to turn on the power supply and the on/off switch was 'mushy' - it will not click on or off but stays in between, like it's been tripped. I disconnected it from the device and plugged it into a different, known to be working surge protected power strip and still nothing. The fuse is ok, and nothing else is available on the exterior to fiddle with.
I'm not too knowledgeable about the inner workings of the power supply so I haven't looked there yet. Am I overlooking a simple solution to 'untrip' this power supply? I called the manufacturer but they are closed til monday. Can anyone point me towards some possible solutions? Any help is much appreciated.
Best,
Chris
Best,
Chris
