(on/off) push button using Flip Flop
Discussion in 'Embedded Systems and Microcontrollers' started by biraaa, Apr 18, 2008.
  1. biraaa
    Apr 18, 2008
    Hi Guyz
    i am looking for the simplest push button Circuit like the one used in water pumpers ..
    Push once to "trun on" push again to "Turn off"
    USING FLIP-FLOPS :confused:
    some one told me that i could Use Daul D FF
    Biraaa
  2. Caveman
    Apr 15, 2008
    471
    Connect /Q back to D. Then use the switch to pulse the clock. Realistically, there needs to be more, but that is the topology.
  3. beenthere
    Retired Moderator
    Apr 20, 2004
    15,815
    283
    A pushbutton switch with a maintained contact (not momentary) can do the same thing without the flip-flop.
  4. Fishman_Tx
    Sep 24, 2009
    Moved to new thread in the Project Forum
    Fish
    I ran across this thread and thought I'd hijack it as it's so old but is very relevant to what i'm doing.
    Using a simple Dual D FF as indicated, using a Schmitt trigger with the "momentary on" pushbutton w/debouncing; I want to drive 2 sections of a 4066 quad bilateral switch for the switching of line level signals. Tho /Q is tacked to D. Can /Q be tapped also to a switch actuator of the 4066? Or would it be better using Master/Slave configuration? The purpose is to switch from one active signal path to another (A/B switch). This will be multiplied into a digital signal switching matrix for my guitar rig. Is there a particular Dual D FF IC that would be recommended? Will the Schmitt give sufficient "edge" to toggle? I would prefer to have leading edge vs trailing for timing reasons.
    It's been a long time away from design work, so forgive my ignorance or "thickness".
    Thx!
  5. ELECTRONERD
    May 26, 2009
    1,146
    16
    I need the exact same idea for this design I'm doing. I'm anxious to see what's the best way.
