On-off Infrared Remote Control Schematic Help
Discussion in 'The Projects Forum' started by tony18183, Nov 21, 2011.
Thread Status:
Not open for further replies.
  1. tony18183
    Nov 21, 2011
    Hi all, I am having problem on the implementation of the circuit. Can somebody show me howto build IC3 , IC2.A , IC2.B
    what is D2? and (14)IC2(7) ?
    many thanks
    links: <SNIP>
  2. praondevou
    Jul 9, 2011
    2,936
    489
    This circuit is using a capacitive power supply, which cannot be discussed on AAC according to the ToS.
    D2 is a zener diode clamping the voltage for the low voltage part to 15V.
    If you use instead of C5 a small transformer and a rectifier after it your control circuit can be made galvanically isolated from mains and we will be able to help you.
    Even worse you will be using 230V. When testing a circuit like this you would need to be very careful to not get electrocuted when inverting the input.
    tony18183 likes this.
  3. Wendy
    Mar 24, 2008
    20,772
    2,540
    I am afraid I have to agree.
    I am closing this thread as it violates AAC policy and/or safety issues. When dealing with power supplies you must use a transformer.
    Quote:
    6. Restricted topics. The following topics are regularly raised however are considered “off-topic” at all times and will results in Your thread being closed without question:
    • Any kind of over-unity devices and systems
    • Automotive modifications
    • Devices designed to electrocute or shock another person
    • LEDs to mains
    • Phone jammers
    • Rail guns and high-energy projectile devices
    • Transformer-less power supplies
    This comes from our Tos:
    Terms of Service
Thread Status:
