Hello!
I'm in the process of rebuilding my 48v 30a ebike and wanted to have a key on/off (ignition)for main power instead of (un)plugging it all the time.
So would the appropriate circuitry involve a ssr-100dd on a heatsink controlled by a key ignition between the +relay and + of 6.4v battery (2x 18650 in series)?
(with load side of relay separating + on 48v lifepo4 and + on motor controller)
I read inductive loads sometimes require 6x current surge during startup. All the ssr-100dd that I looked at never mentioned a surge rating. Is a 100a relay sufficient?
Are SSRs themselves a resistive device? Enough that, with just a ssr in a circuit, will it short the battery? Do I need to add resistors or something? How much current should a relay draw to control(close circuit)
Another relay wiring guide mentioned adding a diode across the load with cathode to + if the relay is going to be used with an inductive device. But because this relay will never be used as a killswitch does that matter?( The controller handles throttle etc.. Keys only get turned during parking) the supposed risk of using as off with inductive device is because the mechanical energy still in the tire inducting power into the wires after relay is shut off
