on delay timer circuit
Discussion in 'The Projects Forum' started by Jonplynch, Jan 28, 2012.
  1. Jonplynch
    Jan 28, 2012
    23
    can anybody help me in regards to an on delay timing circuit.
    what i am trying to do is the following when a start button is pressed it operates a relay which in turn operates the timer and when the timer times out it lights a beacon. the trouble i am having is that i am not 100% sure on the wiring on my first attempt on doing it the circuit worked but only if i keep my finger on the start button as soon as i relase it all power 2 the circuit drops out and it wont latch and i dont know why i also have a nc stop button working as a reset and this is working fine but as mentioned i have to keep the stop button depressed any help on wiring diagram would be most appreciated
  2. MrChips
    Oct 2, 2009
    12,624
    3,451
    Please provide a circuit diagram.
  3. Jonplynch
    Jan 28, 2012
    23
    i am using an omron 230v relay with base a no push button and a normally closed push button i cannot submit diagram just now as i am not sure on the operation of the relays contacts. do i need to power the coil from a different source and then wire the start through the common and no pole on the relay or what ?
  4. Jonplynch
    Jan 28, 2012
    23
  5. williamj
    Sep 3, 2009
    180
    32
    Jonplynch,
    The specifications for the relay displayed in the url provided, states the the relay is a single pole double throw (SPDT)relay. What you need for latching is a double pole double throw (DPDT) relay.
    With the imformation provided I drew up a couple of drawings (one wire diagram and one ladder diagram) of what I think you were after.
    I don't know what your project is but in the future I highly recomend using relays and timers with a lower voltage coil than the voltage rating of the contacts. That's why relays were invented... to use a lower voltage to control a higher voltage. It's much safer that way.
    williamj
