Omron H3YN-4 30 sec delay switch
Discussion in 'The Projects Forum' started by mrben, Jun 19, 2009.
  1. mrben
    Jun 19, 2009
    I'm using an Omron H3YN-4 relay and have a couple questions.
    It seems this relay requires a constant input voltage.
    I want to activate the relay actions and timer to start with a push of a button.
    Have been reading the manuals but am stuck as to where to put the switch (button) that the user pushes to allow the voltage needed to let the timer work.
    110V input
    user pushes button triggers timer which needs voltage to operate so using the switch at the input on cycles the timer off and on for a moment.
    manual says
    External Short Circuit (5-13) terminals
    External Input (9-13) terminals
    Those connections don't make sense to me.
    Thanks,
    Ben
  2. mrben
    Jun 19, 2009
