Omron H3Y 2 power off relay pls help
Discussion in 'The Projects Forum' started by krivis, Apr 30, 2014.
  1. krivis
    Apr 30, 2014
    Hi
    I have bought two H3Y-2 time relays rated 0-30min and i want to do the following circuit.
    To be honest i'm little confused :)
    In my toilet i installed ventilation fan. I want the fan to run during the lights are on and 5 more minutes after i turn off the lights. On hand i have 12VDC relays and 12VDC adapters.
    Thanks in advance.
  2. inwo
    Nov 7, 2013
    2,435
    315
    Which H3Y-2 do you have?
  3. krivis
    Apr 30, 2014
  4. inwo
    Nov 7, 2013
    2,435
    315
    Not the best solution.
    A time delay-off relay, rated at supply voltage is better.
    I'll draw it adapting to what you have.:)
  5. krivis
    Apr 30, 2014
    Thank you :)
  6. inwo
    Nov 7, 2013
    2,435
    315
    I'm still checking for errors.:p
  7. inwo
    Nov 7, 2013
    2,435
    315
    Or this.............................................
  8. krivis
    Apr 30, 2014
    I made the first schematics and it works perfectly :D. Thank you very very much inwo, you save me a lot of time and you saved my bathroom also :D. I hope i will return a favor one day.
    Have a nice day :)
    inwo likes this.
  9. Karel Sovak
    Mar 12, 2016
    I solved the same problem with this scheme. I have 220 VAC relay Omron H3Y-2 AC200-230 30M. So I remove the trigger button and replaced by a normal switch.
  10. KeepItSimpleStupid
    Mar 4, 2014
    1,250
    218
    krivis:
    I've been doing that for years. I actually have a spot light, heat lamp and ventilator.
    Two switches in a single gang box control the light and another controls the fan. The fan has a "delay on break" relay attached to it. I need like 20-30 minutes running after the switch for the fan is turned off. The timer is located in the attic and it needs to be replaced after 40+ years.
    it actually would be better to sense the bath/shower water flow and turn the fan on automatically.
    The IR lamp has a mechanical timer. 30 minutes would be better than 20.
    The next upgrade would be a better check valve and the flow switch.
  11. tevelz
    Oct 10, 2016
    Hi There
    I'm trying to connect a bathroom fan exactly in the same manner, using an external switch.
    I have tried connecting the H3Y according to your schema but no results.:(. when connecting legs 13 and 14 to the mains (one hot and one natural, I hear the relay click and the 2 lights go on. when I bridged 13 and 9 and got the external input from 12, and connected the fan to 1 and .4 it didnt work. it only worked when connected to 1 and 5 but with no relayed off.
    any idea what am I doing wrong?
    thanks in Advance
    T
