Omp Amp Full Bandwidth Problem
Discussion in 'Homework Help' started by crazyengineer, May 29, 2011.
  1. crazyengineer
    Dec 29, 2010
    156
    Hello, I need help trying to solve this problem in example 2.26 of my Microelectronics Book
    " An internally compensated omp amp is specified to have an open loop dc gain of 106dB and a unity gain bandwidth of 3MHz.Find Fb."
    Oringally I thought that I could find fb since
    ft=wt/(2*Pi)
    fb=wb/(2*Pi)
    and since wt=open loop dc gain*wb
    I thought I could find fb by doing
    ft/open loop dc gain=fb
    however it turns out the answer is 15Hz
  2. jegues
    Sep 13, 2010
    735
    43
    20log(A_{0}) = 106 dB
    A_{0} = 199526.23
    f_{t} = A_{0} f_{b}
    f_{b} = \frac{f_{t}}{A_{0}} = 15.04Hz
    crazyengineer likes this.
  3. crazyengineer
    Dec 29, 2010
    156
    OOO! I was afraid to take 20log(A0) because I did not know whether to multiply the log by 20 or 10 (I read somewhere that the gain of a power amplifer is 10log(power gain)
    Thank you so much!
  4. Adjuster
    Dec 26, 2010
    2,147
    300
    You are given the unity-gain frequency in MHz, not Radians/second, so you don't need to worry about conversion. Dividing the unity-gain frequency by the dc loop gain does give about the figure you expect, so are you sure you got the right gain value?
    In the usual definition of voltage gain in dB, we calculate 20*log(ratio). (Purists may object to this except where input and output impedances are equal, but that's life.) Assuming this is so, divide the gain in dB by 20 and raise 10 to the answer to get the gain as a number.
    Edit: I see others have beaten me to it. Ah well...
  5. jegues
    Sep 13, 2010
    735
    43
    That is the power gain.
    \text{Gain} = 10log\left( \frac{P_{out}}{P_{in}} \right) \quad dB
    For the voltage gain, make the substitution P = \frac{V^{2}}{R},
    \text{Gain} = 10log\left( \frac{\frac{V_{out}^{2}}{R_{out}}}{\frac{V_{in}^{2}}{R_{in}}} \right) \quad dB
    Under the assumption that the input and output impedances are equal(This is usually the case),
    \text{Gain} = 10log\left( \frac{V_{out}}{V_{in}} \right)^{2} dB
    \Rightarrow \text{Gain} = 20log\left( \frac{V_{out}}{V_{in}} \right) \quad dB
