old steppermotor
Discussion in 'General Electronics Chat' started by almaand, Dec 11, 2014.
  1. almaand
    Sep 27, 2009
    Hi allI have a bunch of a STEP- SYN stepping motor type 103-710-7 ( SANYO DENKI CO.,LTD ) with 8 wires
    I want to run the motor in bipolar configuration to achive max torque!
    I'm able to find the corresponding leads for eatch coil, and but how do I determinate witch coils to wire up in parallel to to achive this?
    The corresponding coils and wires are:
    Red - redhwite
    Black- blackwhite
    yellow- yellowwhite
    orange- orangewhite
    Thanks in advance
    Jens
  2. bance
    Member
    Aug 11, 2012
    315
    34
  3. GopherT
    Nov 23, 2012
    6,340
    4,094
    If you have a bunch of the same, take one apart and take the mystery out of the process. If you do it carefully, you don't even have to sacrifice it.
  4. mcgyvr
    Oct 15, 2009
    4,798
    979
    Just use a multimeter (set to measure resistance) and keep probing the wire pairs till you find the ones that show resistance..
  5. cmartinez
    Jan 17, 2007
    3,700
    2,802
    This is the conventional wiring of standard stepper motors. You should be able to identify each wire with an ordinary multimeter.
    Gdrumm likes this.
