Old P.U Truck
Discussion in 'Off-Topic' started by loosewire, May 20, 2009.
  1. loosewire
    Thread Starter AAC Fanatic!
    Apr 25, 2008
    1,584
    435
    Been running great not much rain for 8 months,
    today It stalled In roadway after heavy moisture
    for three days.It must be moisture in distribitor or on plug wires.
    You think the moisture would fry contact points.
    Any comments, I have it out of the road. Run great for
    6 blocks and stalled,turns over good.
  2. DonQ
    May 6, 2009
    320
    11
    Water in your distributor does not have to fry your contact points to make your truck stall. Just the moisture can conduct the spark to ground inside the distributor. Also, wet spark-plugs, or even the spark-plug wires getting wet, especially if they are old, can make it stall. Dry it all off. Inside the distributor, the rotor, the wires, the tops of the spark-plugs and inside the caps that fit over the top of the plugs. Then try it again.
    And slow down through the puddles until you upgrade your ignition system.
  3. loosewire
    Apr 25, 2008
    1,584
    435
    No puddle's just sitting in heavy rain without driving,anyway good advise
    will dry everything out. Have honda rebel,need new m/c battery first.
  4. mbohuntr
    Apr 6, 2009
    413
    32
    Wouldn't hurt to check for a cracked cap. If it happens again, I'd replace cap ,rotor and wires. I had a cracked cap on mine, first moisture, it would skip and stutter.
  5. markert
    May 24, 2009
    A relative effective way to find ignition wire problems or external distributor tracking, incliuding those dure to moisture, is to look under the hood at night in the dark with no lights on. If the vehicle won't run, have a helper crank it while you look. Sparking or tracking is usually visible.
  6. loosewire
    Apr 25, 2008
    1,584
    435
    Will let you know mechanic, coming over tomorrow.Tried a bunch
    of stuff new cap,brain.Starting fluid,???????????Thanks for concern.
  7. Mark44
    Nov 26, 2007
    626
    To run, a gasoline engine needs three things: gasoline, air, spark. If you're not getting any one or more of those, it won't run. You can pull out a spark plug and attach the plug wire, ground the plug to the engine, and crank the engine (or have a helper do that). If you're getting a spark, you can probably go on to check something else.
    If after you crank the engine a bit, you should smell gas. If not, that's probably a sign something is amiss in the fuel system.
    It's hard not to get air, but that can happen if your air filter is completely plugged up or you have a big leak in the intake manifold.
  8. loosewire
    Apr 25, 2008
    1,584
    435
    The old p.u. is on the road again,with new brain and regulator,
    new cap. Run two days ,overheated from broken hose. Back on
    the road again. Staying off Interstate until all bugs are out
    from sitting.Thanks for advise mark 44,saving for m/c battery.
  9. Mark44
    Nov 26, 2007
    626
    New brain? Are you talking about a computer? If the engine is fuel-injected, I suppose the truck would have a computer to control the fuel system.
  10. loosewire
    Apr 25, 2008
    1,584
    435
    Mark,you are right fuel Injected,things are so close to us yet we don't
    know without checking.You get so use to getting in turning key until
    you need help.
  11. Wendy
    Mar 24, 2008
    20,772
    2,540
    My trucks been borderline for years, and then the computer finally finished going out. Now it runs like a top. Now if I can only get the AC fixed, it's 100°F+ out there nowdays.
  12. loosewire
    Apr 25, 2008
    1,584
    435
    I arrived home In a cloud smoke today,my smoke the a.c.clutch
    froze up. The old p.u.
