I think this is valid too. Even if we do not have lossless MOSFETs now, we have seen the development of high temperature superconductors. Perhaps someday we will have materials that allow superconducting semiconductor type devices to be built.Interesting discussion! but what if we consider a lossless solid state switch like a MOSFET or a FET? on similar lines as mentioned by Mik3.
It was mentioned that it will be no arcing but there will be EMI.Interesting discussion! but what if we consider a lossless solid state switch like a MOSFET or a FET? on similar lines as mentioned by Mik3.
Would this analysis be along the lines (presented without maths)
Following closure of the switch charge moves to redistribute itself in the system between the capacitors.
This charge has a finite velocity in the conductors, but moving charge generates EM radiation which dissipates.
Once the charge has equilibrated it stops moving so stops generating EM.
One interesting aspect discussed by Choy is the claimed application of this theory to antenna designs that have been patented in the US and GB. He apparently disagrees with some of the claims in those patents, but nevertheless feels capacitor radiation may eventually be used in an antenna design.(in this thought experiment, we)...reduce the wire loop to zero length. In the long wavelength
(λ -->∞) limit, the two capacitors connected by zero length wires can be viewed as an oscillating electric dipole arising from time-varying charges on the parallel plates of C.
Yes. As I mentioned before, they talk about "radiation resistance" in antenna design. This is the effective resistance that accounts for the power loss in a circuit that drives an antenna.What is a bit sketchy for me to understand is that, can Electromagnetic Radiation introduce power loss analogous to circuit resistance? Thanx.
The original post implies that switching must be instantaneous. Non-instantaneous switching means the use of a time-dependent resistor which would seem to violate the "no resistance assumption". One could even argue (note I said "one" and not "I") that the no-resistance assumption implies that there is no arcing, since arcing does not create a zero-resistance path.There is no restriction to say the switching must be quick or instantaneous, or that the build up of charge on the second capacitor must be quick.
I agree that the same result will occur on any timescale. But the slow discharge is less mysterious since we can argue that most of the energy is lost as heat in the resistance. The paradox arises when we take the no-resistance/instantaneous-switch assumption. Here we find that the circuit-theory approximation breaks down. With or without arcing, EM radiation then will be significant. With arcing, it's hard to say how significant radiation loss is, but without arcing, I can't think of any energy loss other than EM radiation.The same result should occur over any reasonable timescale.
Since the wires are "lossless," there would be no damping either? The oscillation would be eternal?Once you add some inductance the problem goes away as what you have is a resonator, the energy simply oscillates between the capacitor and inductor.
With perfect conductors and no dielectric losses, enclosed in a perfectly conducting shield to avoid radiation losses, then the oscillation theoretically goes on for ever.Since the wires are "lossless," there would be no damping either? The oscillation would be eternal?
As mentioned, oscillating current will produce electromagnetic radiation, so oscillations would decay under a classical electrodynamic assumption.Since the wires are "lossless," there would be no damping either? The oscillation would be eternal?
In the world of perfect conductors it is possible to perfectly shield a system to prevent radiation entering or leaving simply by enclosing it in a perfectly conducting enclosure. As the tangential electric field must vanish on the shield, so thenormal component of the Poynting vector vanishes and there is no EM power flow in or out.The concept of EM radiation is a bit unclear to me. What does EM radiation actually consist/compose of? Is 100% shielding of EM radiation possible (ideal world) if so, how? Also, how does EM radiation carry packets of energy? Pardon my marathon of questions, but i did be grateful for a reply
Thanks & best regards,
Shahvir
I don't think you need QM here, you did with the hydrogen atom as we knew what was in it (a positive nucleus and electrons outside) but the problem was to find a stable configuration, and there was no such configuration available in classical mechanics. There were no conductors involved.As mentioned, oscillating current will produce electromagnetic radiation, so oscillations would decay under a classical electrodynamic assumption.
This is a really interesting comment because it reminds me of the old classical paradox about the hydrogen atom. According to classical EM theory, the electron should radiate energy and plummet into the proton. The calculated lifetime is incredible short (sub-picosecond I think), yet a real atom is stable for billions of years. Quantum mechanics must be used to get the right answer.
It's quite possible that the best answer to this question requires QM to describe superconductivity and radiation from accelerating electrons in a superconductor. A superconductor expels magnetic field which only exists near the surface and decays exponentially as it tries to penetrate. So it's not clear to me how well classical EM can apply here. Still there is an energy discrepancy that must get resolved under the proper analysis.
Maybe not. I'm not saying we do, but just that the physics of superconductors is not clear to me. Classical EM theory is not exact and breaks down in some quantum mechanical situations.I don't think you need QM here.
I probably am getting too complicated, but I like throwing in some ideas to think about. However, staying within the bounds of classical circuit theory is getting way too simple. At the very least we need to consider classical electrodynamics.I think we are getting way too complicated here.
It should be possible to explain and quantify this situation within the bounds of classical circuit theory.
Perhaps.Do we not have another example like Prof Lewin's excellent demo?
by Robert Keim
by Aaron Carman
by Aaron Carman
by Don Wilcher
