No I don't, it's 24v and I plan to use 36v or 48v for short bursts. I loaded it up at 48v and it didn't even get warm.Sounds like the way to go. Do you plan on using the rated voltage for it?
PM field although it has 2 extra terminals I can't figure out, that appear to be shorted to each other. Its rated at 3600rpm and I plan to only use large overvoltage to boost torque for short periods while going up hill, once it reaches its normal 36v speed I drop the voltage back down. I've run 24 volt 4000rpm motors on 60 volts in the past and never had an explosive failure even when free spinning with no load.Is it PM or wound field? Early ones were W.F.
What the concern is using >x2 the voltage is you may exceed the safe or rated maximum rpm of the motor.
A rough guide for motor of this type are 2000rpm tops.
Max.
If they measure zero ohms, they are most likely a thermal detection switch, in case of overheat they open up.PM field although it has 2 extra terminals I can't figure out, that appear to be shorted to each other..
What's a good safe limit to stop at in terms of heat on the inside of the casing on the side opposite the fan in F?I would then stop at the top of the hill and make sure the motor is at a safe temp. I'll probably modify a digital oven temp gauge to take the temp of the inside of the motor casing.
Any way to test this without having to overheat the motor?If they measure zero ohms, they are most likely a thermal detection switch, in case of overheat they open up.
Max.
Non that I can think of, short of tracing the wires back by inspection etc. The bi-metal contacts are only opened by heat.Any way to test this without having to overheat the motor?
If that's what they are it's very convenient, I'll just run them in series with the motor, and I won't have to worry about burning up the motor on hills any more. I'll check later today.Non that I can think of, short of tracing the wires back by inspection etc. The bi-metal contacts are only opened by heat.
It is fairly certain if they show 0 Ohms, that is what it is.
Max.
Keep in mind they are not usually made to carry very high current, they often are used back to the motor controller to disable the controlling element.If that's what they are it's very convenient, I'll just run them in series with the motor, and I won't have to worry about burning up the motor on hills any more. I'll check later today.
Good thinking I'll run them to a light by the steering wheel and shut down when it goes off or maybe to a relay so the light comes on when the motor overheats.Keep in mind they are not usually made to carry very high current, they often are used back to the motor controller to disable the controlling element.
Max.
Thread starter | Similar threads | Forum | Replies | Date |
S | Basic N555 Square Wave Generator Circuit | Digital Design | 21 | |
K | 4K signal generator from digital circuits | Digital Design | 6 | |
D | Hantec 1008c signal generator 5 volts and abs sensor 1.50 volts | General Electronics Chat | 5 | |
A | x ray generator | General Electronics Chat | 7 | |
L | Need help repairing a 1950s 20kV power supply | Power Electronics | 11 |
by Jake Hertz
by Jake Hertz
by Jake Hertz
