OLD 1/3 HP MOTOR RUN CAPACITOR
Discussion in 'General Electronics Chat' started by macke, Feb 5, 2016.
  1. macke
    Oct 12, 2014
    65
    Hi I have an old motor marked as THE BRITISH THOMSON HOUSTON CO LTD RUGBY ENGLAND CAPACITOR MOTOR TYPE BKC 2412
    It is 240v 1/3 HP. Unfortunately the rubber insulation on the wires to the capacitor have disintegrated leaving the two leads bare. As it is a sealed metal cap I cannot rewire it. There is nothing written on the cap so how can I determine a replacement value?
    MACKE
  2. Kermit2
    Feb 5, 2010
    3,852
    968
    It is not critical that the value be exact. Close will work.
    See pages 8 and 9 to start with.
  3. Hypatia's Protege
    Distinguished Member
    Mar 1, 2015
    2,850
    1,317
    Is the capacitor defective? -- If the problem is merely the lead insulation, you may measure the capactance (with, for instance, an LCR indicator) the working EMF rating will likely = 330V)
    Best regards
    HP
  4. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    An old BTH 1/3hp I would guess it would be around 2μ to 5μ.
    Max.
  5. macke
    Oct 12, 2014
    65
    Thank you most informative
    Macke
  6. macke
    Oct 12, 2014
    65
    Hi I think it's defective
    Macke
  7. macke
    Oct 12, 2014
    65
    Hi I'll give it a go at 4uF
    Macke
  8. MaxHeadRoom
    Jul 18, 2013
    10,859
    2,525
    I may have spoke in haste, I checked my old motor reference tome and it could be 10μf -20μf.
    Sorry about that.
    Max.
