I was looking at
http://www.okinternational.com/Hand.../Production_Soldering_System_-_Tip_Hand-piece
I read that it uses innovative technology by maintain constant temperature instead of constant power to iron.
1. is its only advantage?
2. There is no display for what is tip temperature. So what the tip temperature I don't know. It must be fix for every model. but I didn't find what is fix temperature for model PG-900
2. is it advisable to purchase it over conventional temperature controlled irons in which you can any desired temperature of iron you want compared to PG-900
